Drawings/dimensioning
0502880
Message 1 of 11
0502880
Hi!
I have got some problems to get proper dimensions of compenents in drawings, if the original body hasn't been modelled perpendicular to origin planes. Also difficult/impossible to get diameter dimensions to drawings in the same circumstances.
Is there some technique to get the proper dimensioning done or have I missed some detail? I have tried to make a duplicate of the component and rotated it as vertical/horizontal, but it's far too difficult way...
Replies (10)
Message 2 of 11
HughesTooling
In the model workspace select the face you want to look straight at in the drawing, then click Look At, icon's at the bottom of the screen. Then in the browser right click Named Views and create a New Named View.
When you create the base view in the drawing select the aligned view as the orientation.
When adding dimensions to the drawing the multi dimension tool doesn't work so you have to use the basic dimension tools.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 11
0502880
Thank's! Hope, that this is not the "final" solution how to dimension this kind components/constuctions... Still can't add centermarks to holes etc....
But anyhow, this solution is better than nothing!
Message 4 of 11
cmiller66
Hi 0502880,
Currently the method Mark outlined (thank you Mark!) is the way to accurately dimension geometry like this in your drawing.  We do have plans on the roadmap (timing TBD) to implement Auxiliary views in drawings and that will ultimately solve this.  For the issues you saw in the named view, we're currently working on making the single dimension, centerline and center mark tools more tolerant of planar drawing geometry that isn't modeled perpendicular to the origin planes.
One thing to keep in mind (as shown n the pdf you attached) dimensioning to non-planar geometry in the drawing view will result in dimension values for the 2D projection of that line in the view, not the actual 3D distance.
Chris
Message 5 of 11
0502880
Nice to hear, that improvements also to the drawings are on their way! Altough 3D printing is strongly present, there is still a lot of projects which needs proper drawings! Please find enclosed my next headache to get dimensioning to the slot. Any ideas how to do it?
Message 6 of 11
Is that slot tapered? It's hard to tell what's going on with the 15.59, 14.78, and 16.1 dimensions. If it's not tapered, the "Aligned Dimension" tool should work.
Message 7 of 11
HughesTooling
If you're using the Muli dimension tool just moving the mouse in the direction you want will change it's orientation. After you've placed the dimension I don't think there a way to change between linear and aligned so you'll need to delete the dimensions you have and add new ones.
Pointer above measured line
Mouse pointer moved to the right makes an aligned dimension.
Mark Hughes
Message 8 of 11
0502880
Thank's for the answer. The problem is, that the original componenent hasn't been parallel to origin planes... So I have first used your "trick" to make named wiev first and after that made the drawing with that wiev. So the "automatic" dimension tool won't work...
Message 9 of 11
HughesTooling
Did you try an Aligned dimension and selecting the line end points.
Mark Hughes
Message 10 of 11
0502880
Yes, it gives better result; but not the accurate one. Probably because there is also 5 deg angle to the other direction... But let's live with that until next upgrade 😉
Message 11 of 11
cmiller66
Hi 0502880,
Could you send me that design?  With the design open expand the File menu > Export... > Type "Archive Files (*.f3d) then save it locally and email it to christopher dot miller at autodesk dot com.  I'd like to take a look at the design and how we can dimension it, and make sure whatever shortcomings we havea are entered in the system as either bugs or (more likely) future feature work.
Chris
