Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Drawings connected to assembly
2 REPLIES 2
joergen_nilsson
118 Views, 2 Replies
Can I somehow keep the connection to a drawing when exporting an assembly?
2 REPLIES 2
If you Export from your Fusion Web Database using the 2D Drawing as you pick, it will export the Model and the related, attached, drawing, as an F3Z file.  This file will not be much use, outside of Fusion as it must be uploaded to the Cloud to be opened.  You of course can send it to someone else and they can upload it.
John Hackney, Retired
Ok, thanks 🙂
