Drawing - Tolerance on a Hole?
Lonnie.Cady
Advisor Advisor
Lonnie.Cady
Is there any work around to add a tolerance to a hole created with the hole tool?
If it were are reamed or bored hole?
jhackney1972
You cannot add tolerances to any modeled dimension in the "Design Environment".  You will have to move to the "2D Drawing Environment" to add tolerances to the hole dimensions.  Autodesk Inventor has this ability but not Fusion at this time.
John Hackney, Retired
Lonnie.Cady
I should have worded it differently.  I am in the drawing environment.
Thank you for the response.  I was just trying out the drawings and seems like it has a way to go still.
jhackney1972
You will have to switch to regular dimensions in the 2D Drawing Environment to allow for the addition of tolerances.  The adding of tolerances to Hole Call Outs is not supported at this time.
