Drawing Title Block Tutorial
Lonnie.Cady
Advisor Advisor
Lonnie.Cady
Does anyone know a good link to a drawing title block tutorial?
I would like to make/customize one for our company and not exactly sure where to start.
Thank you
Marco.Takx
Hi @Lonnie.Cady,
Maybe this link helps.
Fusion-Drawing
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
jhackney1972
Since the layout of a title block geometry is a challenge and you may not have access to AutoCAD or an existing title block layout, I recommend taking a look at this Blog article and video to give you an easy way to use Fusion 360 for the job.
John Hackney, Retired
Lonnie.Cady
Thank you both for the info.
I am trying to find how to add automatic attributes but can't seem to find a list of what ones are available.  I will do some reading from the link you provided.
HughesTooling
These are the only attributes you can use in a title block from the text menu.
Mark Hughes
Owner, Hughes Tooling
Lonnie.Cady
Thank you.  I was hoping for the material, weight etc.....
g-andresen
create a  Partslist
günther
