- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Today I had to make a drawing template to be able to print the title block in Japanese.So first I made the title block using Draft sight ( as I do not have any Autodesk software. Starting position was right bottom. After that insert it in to the Fusion 360 drawing and printed after converting to PDF. Some of the letters and brackets did not appear in the print. Then I noticied that the font type I used in Fusion 360 drawing was not correct. Then changed it to MS referance Sans Serif - everything was perfect. If you have problems like this, try changing the font type.
The only problem I have is, need to input the necessary information in the Draft sight DWG file and then import them.
Hope we have something easy in our Fusion 360.
