Drawing Template Questions (and Requests)
neljoshua
Advisor Advisor
neljoshua
Happy Friday!
I am working on a drawing template. (Btw, I am thankful to have this functionality!) There are a few things that I have noticed and want to ask about.
  1. I see a way to insert a logo in the titleblock, but it currently only accepts raster formats (JPEG, PNG, etc.). Is there a way to add a vector file (such as DXF, AI, or SVG)? If not, can this be added, please?
  2. There is a bit of wonkiness with the text editor. If one double-clicks on an attribute, the entire attribute text will be selected. Pressing Delete or Backspace on the keyboard works as expected and deletes the attribute text. If one double-clicks on a text field, however, pressing Backspace does nothing and pressing Delete exits from the text editor and starts the delete geometry command. This neither seems logical nor intentional.
  3. Can we add the ability to enter custom attributes? I am envisioning something like the way AutoCAD handles these.
Thanks!
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
g-andresen
@neljoshua wrote:
  1. I see a way to insert a logo in the titleblock, but it currently only accepts raster formats (JPEG, PNG, etc.). Is there a way to add a vector file (such as DXF, AI, or SVG)?  NO                    If not, can this be added, please?
    Edit title block runs via browser
    > Sheet Settings > Titleblock >Right click > EDIT TITLEBLOCKHere you can redesign the title block  (text and attributes)
    > EDIT PROPERTIES
    Fill attributes > Left click >
    Insert new attribute content
         custom attributes are possible but not automatically filled via design data but
         must be inserted manually.
günther
jaco_tech
Wait ... how can we add this as a request somewhere ... It is totally illogical that for Drawing templates we cannot add logos in a vector format to the title block ... only raster images.
g-andresen
Even if you can save a vector graphic as PNG, inserting SVG could be a good addition.
Please start a new thread for this topic.
günther
