I am trying to dimension a wheel rim in Fusion.
I have some questions about it.
- The section on the right first was angled because of the angle of the section. Is there a way to project this vertically and in another position than perpendicular to the secion line?
- About the section views. Is there a way to draw a center line for the entire wheel, meaning at the bottom of the section? And I would then also like to make the dimensions on the right diameters instead of radii. I have seen this in drawings but I can't figure out how to do it.
- Is there a way to place the center mark pattern without the dotted line across the entire diameter?
Thanks!
