Drawing not on sketch plane
shadman3000
shadman3000
I have a sketch on a surface that is not coplanar with X or Y.  When I select the sketch and draw a rectangle, it is not coplanar with the sketch, but instead coplanar with the Y axis.  Sometime it works and is on the same plane of the sketch, but I am not sure what I am doing/not doing to make it work.  How do I select the plane I want to draw on?  Thanks a bunch!
Accepted solutions (3)
LeonardoBN
Hi @shadman3000. Try disabling 3D Sketch (last option in Sketch Palette).
Do you have Auto look at sketch turned on? It can help to see the sketch down to you.
Leonardo Brunelli do Nascimento
Chemical Engineer
rajeshpolamuri
Hai @shadman3000
Toggle off the "3D Sketch" Option in the SKETCH PALETTE and select the surface.
Hi everyone, I am Rajesh. I am graduate of Mechanical Engineering in India. I am passionate on creative works like CAD, Art's, Edits, Designing, Etc..... I am also an Autodesk Student Ambassador. I was always shows my interests on the works. Which makes effective and updating every time, With the modern world.
shadman3000
Perfect, thanks!
