Drawing : How do I add a leader to dimension
mufadal89
mufadal89
Please guide me on how do I add a leader along with a dimension like radius
refer imae
cmiller66
Hi mufadal89,
This is a limitation currently, depending on where you place the dimension, especially when dealing with a small radius, you get this extension arc.  We have  a task on our To Do list to handle this better.  Short of using an actual Leader (which isn't a good solution because the value won't update if the geometry does) f you place the dimension to the outside of the radius, you'll get what you show in the image.  There is not an individual setting to switch the dimension styles to adjust this.
Chris
TimeraAutodesk
Hi @mufadal89, thanks for all your feedback on the Drawings workspace - we really appreciate it. As @cmiller66 mentioned, this is an item on our to-do-list (Roadmap).
To see an overview of all of the work we have prioritized to do in the Drawings workspace, and to see a status of them, you might find our Drawings Roadmap Mural helpful - you can find it here: http://mur.al/bW6QNqDW
Best,
Timera
Hi there,
You say that "if you place the dimension to the outside of the radius, you'll get what you show in the image." However, I am not experiencing that, per the attached image:
I would also like the style of dimension that mufadal89 wanted, but regardless of where I put the dimension I never seem to have that option.
Thank you,
Zack
It appears that Fusions 360 currently only allows for this type of leader style when dimensioning in ASME. If you are dimensioning in ISO you can't do it.
t_tackenbergS9X6F
Would it be possible to change this through the use of drawing templates?
