Draw sketch on surface
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
#1
Is it possible to draw a sketch on a face or a curved surface instead of a plane?
This could be a feature of the project tool.
I suppose that if we first project the face on the plane and then draw the shapes using that projection as a guide and then project the drawn shapes back to the initial face it could work. This would be a manual way of doing this, I haven´t tested this idea, I´m just imagining as I write.
A feature to specifically draw on curved faces would be handy.
#2
I also need to repeat a shape along a face but the face is like a trapeze and I need the shape that is going to be repeated to adapt in size along the trapeze and keep a margin to the trapeze edge.
This could be a feature of the pattern tool.
#3
Another thing I need is a feature to clear space within an offset to a face. This could be done manually and its easy on simple shapes, it could also be included during the design process, a smaller object to be used as a tool later... But the best would be to be able to do this at anytime.
Let´s say I have a cube, hollow, 5 faces only, inside a structure to hold it when it is 3d printed but I want that structure to be 1mm away from the cube faces, then at the slicing stage I will set the slicer to merge the two structures, the inner and the outer 5 faces so that the inner structure is not visible on the single wall outer cube.
Sounds strange but this is exactly how the object attached to this is made. Watch the second image, the inner structure with the small holes, it is 1mm apart from the outer shell.
These features would allow fusion to be able to draw model airplanes that would then be 3d printed.
Without them its a pain.
