10:22 AM
- Mute
- Permalink
- Report
I am trying to create a line on a cylinder to use as a path for a spiral extrusion. I tried drawing two rectangles on two different planes and using the loft function, but the swath cut is not even along the length of the cylinder. I have seen a video on projecting lines for creating helical gears, but I need to hit specific angles on the cylinder. I want that rectangle to be cut from 0deg (bottom of cylinder)to 22.5deg (top of cylinder), 90deg (bottom of cylinder) to 112.5deg (top of cylinder), etc. Any help would be greatly appreciated
