Draw a shape, convert it to a body, pattern it around a point
chrs.purser
Observer Observer
chrs.purser
Observer
Observer
I'm brand new, as you've heard a million times.
I've gone through about 10 tutorials that all seem to start with an object already created or a premade shape in F360.
The problem is none of those pre-existing shapes work for me.
So, I want to draw a shape with lines, connect them, fill the space in between, pattern this shape around a point then extrude the whole thing as one piece.
The simplest way to describe this would be this:
  • Create a 60,60,60 triangle using 3 lines.
  • Fill the triangle
  • Pattern the triangle 5 more times around one of the points, 60 degrees per, which shoul dleave you with a hexagon of triangles.
  • Merge all the triangles together
  • extrude the hexagon n mm.
I've been fighting with it for more than an hour and no matter what I do, no matter where I go, when I choose pattern and it asks me to select a body, I am unable to select my triangle.
lichtzeichenanlage
That's way to complicated. The polygon tools are your friends:
DDMFGCOINC
@chrs.purser
In addition to what @lichtzeichenanlage stated above, realize that there are quite a few tools that will only work with a solid body/ component and a tool with the same name that works with sketching.
The fillet tool is another tool that, like pattern, has one tool for solids and one tool for sketching.
You have to be sure you are selecting the right tool.
jasonhomrighaus
Here is a screen cast to help you along
If this helps feel free to click on the solution button.
chrs.purser
Observer
Observer
Yeah,  I used that as an example. The polygon tool won't work for me here, which is why I described it in the way I did.
chrs.purser
Observer
Observer
Thank you for the example. That's exactly what I was looking for.
Where I got stuck was on the selection of the object to pattern.  I assumed I needed to select the triangle as a single entity.  I should have tried grabbing all the lines.
This is exactly the solution to my problem.
Thanks again!
lichtzeichenanlage
Okay.. it was just an example... New thougts:
It's preferable to use feature based patterns over sketch patterns. Small sketches are more stable and faster in Fusion 360. This is also true for feature based patterns especially if you are using faces.
