Combine Failing
Combine Failing
docara
Message 1 of 8
Combine Failing
docara
Hello everyone,
I'm having an issue with combing two bodies. There are no linked items and I have faces intersecting.
I have exported and uploaded the component in question from a bigger design.
Many thanks
Matt
Replies (7)
Message 2 of 8
HughesTooling
You have some not very nice looking surfaces here that stop the combine working, deleting them fixes it. see attached file.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
docara
Hi Mark,
Thanks for the reply.
Well spotted!!
I have deleted the face you mention and rebuild solid but not difference I'm afraid.
Yes, there are some others but these will get sorted when the combine takes place and I add some othe things to the solid.
Any other thoughts?
MAtt
Message 4 of 8
HughesTooling
Not really it worked in the attached file. Attached the wrong file in last post.
Mark
Mark Hughes
Message 5 of 8
docara
Which method did you use to correct those edges?
Matt
Message 6 of 8
HughesTooling
If you edit the features I created in the timeline it'll show the faces I deleted, note the 2 undercut faces in the corners.
Mark
Mark Hughes
Message 7 of 8
docara
I followed Mark's method using Patch environment initially and it didn't work. I tried again and I deleted an internal face. I then used Offset and Loft and the Combine in the Model environment and it was successful.
Matt
Message 8 of 8
HughesTooling
If you delete all 5 faces in the model workspace Fusion will heal the model for you, you need to select all the faces at the same time then press delete.
Mark
Mark Hughes
