Draft Analysis colors explained
nkloski
nkloski
I would love to get a description of the colors assigned when running a draft analysis.
I think I understand it, but if someone could please fill me in (and fill the non-existent documentation on color assignment) on the colors for what means what that would be great!
As far as I can tell  (this is for the pull vector and draft angle you specify):
Green = OK along positive value vector
Blue = OK along negative value vector
Red = Not OK along either chosen vector
Turquoise = ???
Thanks!
Nick Kloski
Turquoise = it's just selected/highlighted face.
It's tolerance zone between red and blue. Also there is yellow zone - tolerance zone between red and green.
And sometimes it flickers with Turquoise color for perpendicular faces. Glitch?
nkloski
Yeah, it was that flickering that was not consistent...changing draft angles sometimes makes things one color, then another.....so you are saying that turquoise is the completely flat/perpendicular plane to the pull direction (in both positive and negative directions)?  Yep, that seems like that explains it...
Clicking quickly through the Tolerance checkbox seems to produce varying results, though.  It should be on or off, and sometimes if you click quickly, it seems to get confused?
Nick Kloski
nkloski
Maybe I am thinking that is a bug...can someone from AD see if this is something to check out?
Nick Kloski
davide_vicenziDW3QZ
Observer
Observer
how can I modify color of draft analisys? my goal is
GREEN = OK along positive value vector
RED= OK along negative value vector
BLUE = Not OK along either chosen vector (or flat surface)
thanks
