Doing different depths with shell
Message 1 of 8
Hi, I am just practicing fusion with this drawing,but I'm stuck on doing the shell at different depths. If someone could point me in the right direction that would be great....Thanks!
Replies (7)
Message 2 of 8
davebYYPCU
Because the inside fillets in different sections are not the same radii,
This will the first step,
Inside fillets next, add through holes and bosses, outside rim, and then outside fillets etc.
Might help....
Message 3 of 8
davebYYPCU
Before you get to far, your sketch is misleading, and has some errors.
Principle is the same, extrude join 3 main sections for the external shape and
remove bottom face with internal shell, before adding more features.
Might help....
Message 4 of 8
chrisplyler
Let's say for a second that you didn't care about the inside fillets having distinctly defined radii that aren't always the same relative to their associated outside fillets. Okay, let's just imagine that's the case.
Assuming the wall thickness is the same throughout...why would you need separate Shell operations? And what do you mean "depths" in the context of a Shell operation?
Message 5 of 8
TheCADWhisperer
Check back later and I will show the correct way to model this part.
1. I will not have any dimensions on my sketches that are not on the original drawing.
Dimensions have meaning (in terms of Design Intent and at time of Inspection).
Message 6 of 8
Thank you for showing me how to do this the right way I appreciate it!
Message 7 of 8
Hi, I guess my question should have been more like how do you extrude different depths on the same sketch rather then asking about the shell...sorry about that.
Message 8 of 8
Yes I have a hard time with constraints any advise would be great...thanks!
