Does anyone actually use RMB gestures? Just curious...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'd like to know if other fellow Fusion 360 users use RMB (right mouse button) gestures, the ones where you hold down the RMB and swipe in a given direction before the context menu shows up.
The idea of gestures is to access items of the RMB circular menu without actually displaying the menu. To do this, users swipe the mouse preemptively in the expected direction of the target menu item, before it is displayed. So for example, "Undo" always appears to the left of the mouse pointer in the circular menu, therefore swiping leftwards always executes the Undo command. Other common actions are Redo (swipe right) and Repeat last command (swipe up).
For me this feature poses a couple of problems:
(1) Accuracy: It's quite easy to swipe in the wrong direction when the menu is not yet visible, since there is no visual feedback of where the mouse pointer is heading. Thus, I may end up triggering Undo (left swipe) when I meant to Delete (left-up swipe) if the swipe was not upwards enough. Because I need that visual feedback, the very few times I choose to use the circular menu I usually just do a regular RMB singel-click (i.e. fully releasing the button), wait for the menu to show up and then LMB click the desired menu item. Sure, "blind" gestures would save me about 500 ms, but for me it's not worth it if there is room for mistakes. This method requires one extra click but it is accurate. I also rely on keyboard shortcuts as they tend to be very accurate.
(2) Ergonomics: I will add that orbiting is the second most frequently performed action in Fusion 360 (only a close second to selecting stuff i.e. clicking the LMB), and yet it requires the use of the Shift key and moving the index finger from the LMB to the MMB. This violates the most basic principle of ergonomics, which is to minimize displacement from the "home" position. The middle finger's home position is the RMB, so it would make sense to use that finger and that position to execute one of the most frequently performed actions i.e. orbit. RMB gestures should be optional to allow the RMB to be used for orbiting. I could be completely wrong, but I'm sure most users would disable gestures.
Furthermore, I've watched countless video tutorials by power users and I don't remember any one of them ever using gestures, they all wait for the menu to show up and then click the target item (of course this may be partly because it is a tutorial where clarity takes precedence over speed).
I'd love to hear everybody's comments, cheers!
