Does a Revolute joint freeze upon entering into a Rigid group?...
Hi, all-
...If so, how do you get around this?
I need to move a swing arm (an inch toward the rear), and created a rigid group to get all related components to go with it.
Seemed fine, except the kick stand will not swing up/down anymore (revolute joint)...and I cannot figure out how/what/why.
Any help would greatly be appreciated.
-G
Beyondforce
Hi @Anonymous,
I would like to help, but I need the file.
Could you please attach it?
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
jeff_strater
This should be OK.  The only problem that I can see is if you mistakenly selected both sides of the revolute joint to be in the rigid group.  If so, though, you should see a warning similar to this one:
And, as @Beyondforce says, if you share your design, we'd all be happy to take a look at it.
Jeff
Jeff Strater
Engineering Director
I futzed around with it, un-doing the mechanics of it--then re-doing it all. And it worked. Yes, I did the exact things and it worked the second time.
I cannot explain why. Frustrating, for sure.
Thanx for the replies, however.
I appreciate your time.
-G
