Hello, I need to divide lines and spines into equal parts, like you can see in this AutoCad Video:
https://www.youtube.com/watch?v=Bn8Is07B0do
How can I do this in Fusion 360?
Thank you
@Anonymous
I believe per our discussion this is what your after....
Phil Procario Jr.
Owner, Laser & CNC Creations
Nice video... thanks. What if my line isn't an exact "8 inches"? Can I set the distance based on the second point?
For straight lines and splines, measure it first, then enter that number as the Extent.
For arcs, measure the angle first.
For ellipses, you need to define what you mean first
ETFrench
Hi Mr. Mendonca,
If you have some F360 API proficiency look at:
<CurveEvaluator3D Object getStrokes>
It is not difficult to write the appropriate function. For TF360 members with the access to F360 core guts, it would be a breeze!
Regards
MichaelT
You can use a dimension as a reference in the pattern. Before starting the pattern feature hover the mouse pointer over the dimension you want to use and note it's parameter, in the screencast below it's d1. The screencast is for an arc but the same procedure works for a line. Note, you don't need to add a point to the start of the line\arc you can use it's endpoint.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks Mark,
I think this would meet my needs if I could reference driven dimension as discussed here:
(I can't tell if this is still in development or not.)
What I have is an edge whose length is driven by other constraints. Then I want to subdivide that. Each time I change the other constraints, I need to edit my timeline and do a measure/copy/paste. It would be great to add the driven dimension, give it a variable name, and then set that variable name as you suggest.
Darryl
Referencing driven dimension is still not implemented I'm afraid. Your only workaround is if you can calculate the length from the dimensions you have, see this thread\post for an example. You might need to use a different workflow, do you have an example design you can share? Export as an f3d and attach if you have an example.
Mark
Mark Hughes
Gotcha, thanks. I think I can rework my design to allow me to compute the dimensions myself. For now, I don't change things around that much, so if I have to manually update the pattern length, I can live with that. (If I get stuck, I'll post the specific problem for guidance!)
You don't select the dimension. You hover over it to get its ID (name). Once you have the ID, use that in a formula.
You can also get the ID in the Change Parameters dialogue.
ETFrench
Thank you, Phil. For the spline, I replaced the point with a sphere (Outside of the sketch) then used the "Pattern on a path" for body. After the pattern, I created a new sketch and projected both the spline and the spheres.
Thank you so much!
