Hi @shaische222
"What's the proper way to read the force required to pull out the pin from the results? Is the "Reaction Force (Y)" the correct selection?"
No, that is not the correct way. That is graphing the one node (of 10, 100, maybe 1000 different nodes) that has the largest reaction force. What you want it the sum of the reaction forces, using either the nodes that are constrained on the clip, or the nodes with the prescribe translation on the pin. You cannot get a graph of this. You need to use "Inspect > Reactions" and step through the output steps 1-by-1 to find when the largest result occurs.
If you did not apply an initial velocity to the pin, then some fraction of the reaction force on the pin is the load that it takes to accelerate the pin from 0 velocity to Y velocity.
There will probably be a lot of vibration occurring, so the reaction force may jump up and down. You probably want to use some type of average over several steps to "smooth out" the vibration.
"You mention to run static stress analysis, but how would you set that up properly?"
You know how far apart the legs of the clip need to move; they spread apart a distance equal to the diameter of the pin. So model the clip only and apply a prescribe displacement necessary to separate the legs the diameter of the pin. The result will be the force required to separate the legs. From knowing that force, you can do a hand calculation to estimate the force required on the pin.
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided already, be sure to indicate the version of Inventor Nastran you are using!"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
