discarded toolpaths
discarded toolpaths
tjtolrud
discarded toolpaths
tjtolrud
Having trouble with discarded tool paths with the attached file.  The "D" seems to be missed on the simulate, even tho it is selected in the geometry section.
I cannot find any thing wrong, I am fairly new to this forum.
jhackney1972
I have attached your model with I think is a correct toolpath.  Please note in the screen capture below you have a defect in the sketch path of the "D" I think you will want to correct.
Edit: Attached file was replaced, you had missed a section of your art.
John Hackney, Retired
tjtolrud
Thanks John.  Didn't realize those parameters were the cause of the problem.  I did correct the loop on the "D".
Thanks again
