Disappearing Origins
etfrench
Mentor Mentor
etfrench
Whenever the view is set to 'Top', the Origin disappears.  It doesn't matter which origin is visible, all disappear.
I've seen this in other files, but it doesn't repro in the other files currently open.
Attaching screencasts to forum post is currently broken (no Insert or Preview buttons).  Here's the link:https://knowledge.autodesk.com/community/screencast/72fe1b51-6b85-4bbc-841b-cfa74e99b1f0
ETFrench
jhackney1972
If you use HTML tool, in the menu bar, and the Embed code from the Screencast, you can attach a Screencast without failure everytime.
John Hackney, Retired
TrippyLighting
@jhackney1972 I've received feedback from at least one other user, that the HTML method I've used for the last 2-3 years without a single failure does not work for them either. Pretty disheartening to see that one of the biggest and most successful software companies in the world cannot manage to put that to rest for good!
I can see the field for pasting a screencast URL below the text field I am typing in.  I have to admit that I find the HTML method faster by now and have no intention to test if the "normal" method actually works.
This is in Safari on macOS Catalina. Results sometimes vary depending on OS and Browser.
jeff_strater
screencast issues aside, I can reproduce the issue here.  Very weird.  You broke Fusion graphics!  I'll send this off to the graphics team to look at.  Thanks for reporting it and adding the design, @etfrench
[edit] the bug is FUS-75971
Jeff Strater
Engineering Director
keqingsong
Update on this - we just released our latest product update and have fixed this issue.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
