Help with Runic Text
CuttingEdgeManufacturing
Hey guys,
working on a fun little christmas gift involving some wooden dice and cards.
dice are running right now in the machine as i work thru the rest of the job.
im making a game that i found in a video game (assassins creed Valhalla).
there is a mini game called orlog, long story short i need to have some runic text like below added into fusion as a sketch for a single point engraving toolpath...
ᛏᚻᛖ ᚷᚪᛘᛖ ᚩᚠ ᚩᚱᛚᚷ
learned pretty quickly that fusion just gives me blank squares or ???.
is there a workaround for this?
i have 20 different phrases to do with the one provided being included in that list.
please help!
etfrench
Try using Inkscape to create an SVG file for each block of text.
ETFrench
will give it a go!
WyzeOwl
One workaround I have used for developing text like your runes is to use an svg app like Inkscape. From here you can import the svg into fusion and use the line work to create a cut path. You can use an image of the runes as a canvas, then draw line art on top. Not easy but doable.
Cheers
Chris Westerby
647 393 8030
