Disable snapping temporarily
smallfavor
smallfavor
Is there some modifier key or combo that disables grid snapping temporarily?
Beyondforce
Here you go:
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Hi @smallfavor
On my Mac I can hold the Command key down to disable snapping.
Guessing Window key does the same thing if your not on a Mac.
What about while moving in sculpt mode? It'll snap snap to even mm's whenever moving in only one axis...
@Anonymous
Not sure if there is a way other then unchecking the box for "Incremental Move".
@Anonymous that'll do just fine - thanks for the tip, gosh figuring out all the little quirks of this program has been the most difficult part so far 🙂
