Disable Auto-Arc feature when drawing lines?
Silv3rDragon
Silv3rDragon
It took a bit to figure out what was happening but I finally learned that the tiny little arc segments in corners of my drawings were coming from ever so slightly dragging the mouse while clicking with create line.  I like to quickly draw up some straight lines and add dimensions after when to my surprise I find several arcs show up out of no where or dimensions not working correctly due to the arcs in the corners.  Is there any way to disable or remove this feature from the drawing straight lines?  "Just slow down" is also not a solution as it is the same as saying "just take longer on everything you do".  If I want arcs in corners of my drawing the fillet feature works great for that and see this auto-arc feature as a poor version of it and I never intend to use it.
jhackney1972
No, this feature cannot be disabled.
John Hackney, Retired
Silv3rDragon
I would also guess since it has been around for a while that they have no intention of adding a way to disable it?
jhackney1972
Probably not.  You can create a new Forum post with a title that suggest a new feature request if you like.
Silv3rDragon
Ok.  I will try to look into that if I get the time, thank you.
