Dimensions nit snapping properly
jeffescott
Advisor Advisor
jeffescott
Fusion seems to have stopped snapping properly
on a simple line snapped at both ends.  The dimension will be say 10.00000789.  Rather than 10.0000000
i have seen problems occur with intersections etc. If the dimension isnt bang on. Or i would totally ignore this
Pradipio
Autodesk Support
Autodesk Support
Hi @jeffescott ,
Thanks for posting to the Fusion 360 Forum.
Can I have a small video representation of the issue that you are facing? it's a bit difficult to understand without a video or a file.
Also, you can share your file and highlight the problem area.
THANKS
Pradip Mistry
”Community
TheCADWhisperer
Are you typing in parametric driving dimensions or are you simply “eyeball” snapping to grid?
jeffescott
sorry here is file
i created a new sketch see sketch 26
i created a  two point rectangle snapped to the grid.
The dimension says 15.00 so okay but when i click on the dimesion it says 15.0000002235
TheCADWhisperer
@jeffescott
I am on vacation with no access to Fusion to check your file, but I can tell you I turned off snap to grid in my second CAD class back in 1987.
Went on to teach CAD for nearly 30 years and we never used snap to grid.
I recommend typing in precise parametric dimensions.
Hopefully someone will come along and Reply with a video of the technique (that works in any CAD software - returning absolutely predictable results).
jeffescott
enjoy your vacation
