Dimension upon sketch creation
Weird thing happening over the last couple of days.. When I create a circle and input the dimension, when I hit enter, that value doesn't "stick" and defaults to where the cursor is placed. Also when creating a rectangle, I can input the first dimension then tab to the second but that value doesn't "stick" either. Straight lines work as long as I don't have to change the second dimension (angle). Slightly annoying because I end up having to go back, double click and enter the desired value.
Tries restarting Fusion but have the same results. Any ideas?
Thank you.
jeff_strater
are you running Fusion on Windows 7?  See these other threads:
Jeff Strater
Engineering Director
g-andresen
possibly it is a problem described in this thread and is typical for W 7
Workaround:
1. create elements > ok
2. create dimension > ok
Yes, Windows 7.
Thanks for the reply!
