@free2fly1, I need a little more context to understand the problem. If dimensions are missing entirely, this suggests an issue with that Dimension command more than the font it would use.
Would you please provide a screenshot or recording of the behavior? Or, a GIF/MP4 from your favorite screen recorder will also work.
- Fusion 360 integrates with Autodesk Screencast (free), which you can access from File (next to the Data Panel/above the Workspace Switcher, not the macOS top menu) > Share > Launch Screencast Recorder. You will likely need to grant the application several Privacy permissions in order to capture your screen, commands and keystrokes, and your commentary (optional). At the end, you will get an Autodesk-hosted link to the video (you can change it to Unlisted), and we will be able to see the exact order and timing of command activation.
- You can also use Apple's Quicktime Player, included with macOS, to record all or a portion of your screen.
You might also try resetting your preferences by clicking your account name in the top right > Preferences > Restore Defaults in the lower right. If you have installed any extra addins beyond those that come with Fusion, try turning those off.
Finally, if you would kindly provide some system specifications, that may help narrow down the issue; a screenshot of About This Mac would suffice.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
