Dimension lines width and opacity
lchiu
Observer Observer
Message 1 of 8
lchiu
Observer
Observer
The only settings that is showing up and I could change in the Documentation Settings is Units. Isn't there supposed to be other settings I can change? I want to be able to make my dimension lines faded but I can't do it without having it as a setting in the Documentation Settings or the Preferences.
Replies (7)
Message 2 of 8
Drewpan
Exactly what dimension lines do you mean and why do you want to change them? The Documentation part of fusion
will create Engineering drawings to the appropriate Standard. Is there some special reason you need to change the
Standard or is it asthetic reasons?
If you mean you want to change the lines in sketches then that is in the modelling environment and is possible or
you could simply switch the visibility on and off.
Can you please provide a screen shot of an example to help us work out what you want and why.
Cheers
Andrew
Message 3 of 8
jhackney1972
You will not be able to change the opacity of your 2D Drawing dimension lines but you can control the line weights.  In the drawing environment, click on document settings and on the first tab you will find Line Widths.
John Hackney, Retired
Message 4 of 8
g-andresen
something like this?
günther
Message 5 of 8
lchiu
Observer
Observer
That's exactly what I was trying to change but I can't find where to change these settings. I think my fusion doesn't look the same as yours.
Message 6 of 8
jhackney1972
Since you are using the "Post Reply" icon instead of the Reply icon on the specific post that you are referring to, no one knows who you are addressing with your comment that you cannot find the settings.  Please clarify by using the Reply icon on the post you are referencing so you are addressing the specific poster and not "yourself".
Message 7 of 8
g-andresen
Unfortunately, you did not answer @Drewpan question (design or drawing?).
From your screenshot, however, I assume that you mean dimensioning in design mode.
There is no way to influence the design of dimensions for these.
My note refers to the drawing mode.
günther
Message 8 of 8
jeffescott
If you want to change opacity in sketches.  There is a work around.
If you create a component then add a sketch then with the old component visible but dimmed.   You can then add the important ones to the new sketch.   The are opaque.
not great but i end up there now and then
