- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Noob q:
How can I enforce a specific distance between a plane (or face) and another face?
See attached pic.
I'm making a simple wheel rim, the center hex (hub) is suspended at the moment (haven't drawn the spokes yet), and I need it to be a specified distance from the edge (bottom plane). Currently the hex is extruded with an offset from a sketch on that bottom plane (raising it up 10mm), but I want to enforce a distance in the sketch rather than an offset in the extrusion/body.
The dimension tool is causing the following problems for me:
- Can't seem to select a plane, edge or point depending on what body or sketches are in the way (blocking view, annoying, but resolvable)
- Doesn't seem to apply to a face
- Cant select a plane to set a dimension to
- Can't seem to set a dimension between two different sketches, even if I do try and select an edge or point in each
I'm new to Fusion 360, but not to CAD in general. The biggest hurdle moving to 360 seems to be just selecting things and understanding which tools apply when (and why they don't when they dont). Grrr. In this case specifically, I am likely trying to select and apply things for the Dimension tool with the wrong approach. Anyway, tips on this much appreciated!
