Difficulty fixing complex joints
evandiplacido
Message 1 of 9
evandiplacido
I needed to make a change very early in the timeline, which caused some downstream failures. I was able to fix all of them except for the Axis 4 joint system.
Here is an older version that shows what it should looks like (v35):
Here is what it looks like now (latest v40):
You can see that the Axis 4 metal rod (highlighted in red) is not in the correct place. It has been moved and rotated.
Please open the older v35 file, hide the housing, then playing the Axis 4 motion study to understand what the animation should look like.
How do I fix this issue?
Replies (8)
Message 2 of 9
davebYYPCU
I can’t access the files while travelling.
Edit the Revolve Joint for that rod, deselect and reselect (Joint position) the correct alignment, for it.
Might help......
Message 3 of 9
evandiplacido
When I try to edit the joint, it does not let me select components.
Message 4 of 9
jhackney1972
I took a look at your model and I am puzzled.  Why are you using bodies, instead of components, to create most of your design parts?  I know you are using components for commercial parts but using bodies for the rest really makes your modeling job very hard.  Your timeline is chocked full of Move commands and Capture Designs, if you had used Components assembly joints would make your model a lot easier and cleaner.  Also the use of bodies make it much hard to edit and correct problems.  I took a screen capture of one of your sub-assemblies to show you want I mean.
John Hackney, Retired
Message 5 of 9
evandiplacido
I'm relatively new to Fusion 360. I will use more components instead of bodies in the future. Thanks.
Message 6 of 9
davebYYPCU
Are you saying the Revolve Joint (simplest way to locate it) does not exist?
Therefore you don’t know why it moved.
Message 7 of 9
evandiplacido
The joint exists, but I cannot edit it, and I also don't know exactly why it moved.
If I try to delete it, then add a new one, it results in conflict.
Message 8 of 9
davebYYPCU
Edit Joint, not to change components, but changing anchor point location, should be available.  Cancel the current anchoring point, and changing to the correct location.
There is a possible chance of getting to a desktop, sooner than expected, but don’t hold your breath.
Might help......
Message 9 of 9
evandiplacido
Trying to make any changes to any of the joints after making that change early in the timeline (the one I mentioned in my OP) always results in a lot of downstream failures. I have been playing around with it for a couple hours, but I have a new idea. I will just revert back to my V37 before I made the change, then copy the new body that was changed from my V40 and paste it into the V37. Then I will save the V37 as the latest.
Edit: It worked great.
