Different Wall Thicknesses - Shell Command
docara
docara
Hello Everyone,
I would like to use the shell command to 'hollow' out a plate but need one of the walls to have a different thickness to the others - is this possible? Alternatively is there a workaround other than drawing the desired offset lines and extruding?
Mat
lichtzeichenanlage
Shell is producing the same thickness for all shells / walls. You can "Press/Pull" the e.g. bottom with the offset type "New offset"
docara
Fantastic - thank you so much
suril15104
Community Visitor
Community Visitor
Is there a way to do this uniformly i.e. give a certain range of thickness to the beginning and end of the body?
davebYYPCU
You mean a taper wall?   Draft will do it.
Might help.....
suril15104
Community Visitor
Community Visitor
I see.
I want to actually make a cone which has different amount of thickness going from bottom to top.
The loft feature already helps me create a tapered wall but I want to play with the thickness. Can i do it using the draft feature?
davebYYPCU
Probably, it works but you would have to assess it for your purposes,
I would use Revolve, myself.
