Different length and angle spline handling points
theIiadir
theIiadir
Hello
Is it possible to individually ajust the length and maybe the angle of the spline handlers?
In the attached image I drew what I mean. I want to ajust individually the length of x and y.
davebYYPCU
No.
LeonardoBN
If you have two different slipnes, with colinear tangents at a point, you should be able to dimension them indepentently.
Edit: I mean Tangent constraint between splines, not Colinear between handles, which will not work.
If you need to use this in few points it can do the work, but it can be tedious for a higher number of points.
Leonardo Brunelli do Nascimento
Chemical Engineer
theIiadir
I will just create individual splines instead of a long one.
LeonardoBN
Oh, I didn't notice you wanted to change the angle as well. So you really need two splines, as we can't "crease" a spline point.
Chemical Engineer
