Different fillet rad per edge.
HughesTooling
Consultant Consultant
HughesTooling
I'd like to be able to specify the radius for each edge individually.
Here's an example where I want one big radius of 25mm and the rest 5mm. Because you have to make the 25mm separately you can't use the set back option on all the radii.
And this is what I want done with another program.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
schneik-adsk
You can do this today. Expand the selections area of the Fillet Dialog and create multiple edge sets.
Kevin Schneider
schneik-adsk
Kevin Schneider
HughesTooling
@schneik-adsk Thanks that works really well, even allows variable fillets in the selection. The table that holds the selections could do with some tuning up though, it doesn't fit in the scroll bars very well when you have more than 4 selections.
Mark Hughes
