Differant flange height on each end
wallenaircraftllc
Message 1 of 15
wallenaircraftllc
I am making a part and am having problems with the flange tool. Its probably really simple but all I want to do is when I make a flange for a sheetmetal part as the flange extrudes I want one side to be an inch lower than the other and I cant figure it out. Thanks in advance as this is probably really simple.
Replies (14)
Message 2 of 15
TheCADnoob
This is posted in a general community forum, so we don't know the context of your question. What program are you using?
CADnoob
Message 3 of 15
wallenaircraftllc
Sorry about that. I had never posted on here before. Using Fusion 360. Whats the best forum to post on for Fusion 360?
Message 4 of 15
TheCADWhisperer
@wallenaircraftllc
Do as two separate Flange features
or
as one feature and then edit side as needed.
It is really simple - just as you suspected.
Message 5 of 15
wallenaircraftllc
Thanks, So on the top plane i want the length at the end of the flange to be 17in instead of the 18in at the base. I couldnt figure out how to push pull or edit it to pull that one side in 1in. Im obviously still learning but getting there.
Message 6 of 15
TrippyLighting
I would start by properly constraining and dimensioning the first sketch.
Message 7 of 15
g-andresen
something like this?
günther
Message 8 of 15
wallenaircraftllc
No I attached another sketch with some text that might shine some light on what I'm trying to do. Thanks.
Message 9 of 15
g-andresen
1. measure the angle > left click (copy to clipboard)
2. Draft > pulldirection > face > ctrl+v  angle from clipboard
günther
Message 10 of 15
wallenaircraftllc
Thats it!! Thank you guys so much for your help!!
Message 11 of 15
wallenaircraftllc
After I did the draft it will not let me make a flat pattern in sheetmetal.
Message 12 of 15
g-andresen
Probably this way is better
günther
Message 13 of 15
wallenaircraftllc
Perfect. Man I hope I can become as proficient at this as you guys some day. Thanks again
Message 14 of 15
wallenaircraftllc
I made that work but it import it to get it cut out and bent it has to be in the sheetmetal flat pattern file. It still wont let me make a flat pattern with it. I can unfold it like you did but to make a flat pattern it gives me an error.
Message 15 of 15
g-andresen
should work
günther
