Hi @rbtyod, it was nice meeting you the other night at the Portland area Fusion meetup.
II took a look at your warnings. I didn't look at every one, but the ones I looked at seemed to have a common theme. These were all "missing body references". These are warnings generated when an operation that requires a body to be selected can no longer find that body. Normally, body references are pretty stable (as opposed to edge references, which can sometimes fail due to edits), but these errors can occur at times.
So, as an example, let's look at the first warning in your design: "CustPasteBodies1" in the "Roof Pieces" component. It's a little less than halfway down the timeline.
the problem with an error in this particular feature is that there is no Edit Feature for it. So, you have to kinda poke around a bit to debug it. In this case, the clues are that the target component is "Roof Pieces", so we know to start there. I then just rolled the end of design marker back and forth over this feature to see what I could notice. The "CutPasteBodies" feature is pretty much what it says it is: a cut and paste of a body. Or, a "restructure" operation (dragging a body from one component to another), which is what I suspect this feature is. Looking at the before and after picture, we can see that the result of this feature was to paste a body called "Left Gable End" into the "Roof Pieces" component.
Before:
after:
So, I looked around for that body in the "before" state. I could not find a body anywhere that matched the "Left Gable End" body, either in name or in geometry. The closest thing that I found was a body in the "End Pieces" component called "End" that includes the geometry from "Left Gable End", but not as a separate body:
So, I can't really debug it much farther without input from you. Do you remember this body? Was there a separate body for just the gable at one time? If so, did you by any chance delete it?
The thing to remember with these type of body-level operations is: they are strictly history-based. If you do something like:
- create a box, call it body A
- split the box using Split Body, into Body A and Body C
- create a new component called NewComp
- drag Body C into NewComp
- roll back before the CutPasteBodies feature
- Remove Body C
- roll forward
you will get a similar error. Or, even if you make some other edit, such as changing the splitting plane so it no longer intersects BodyA, you can also get this type of error.
So, if you have any more information on the whereabouts of "Left Gable End", we can go from there.
One last point: When these failures occur, Fusion allows the rest of the compute to happen. This is because we cache the body in the CutPasteBodies feature. So, we do have a body that we can copy, it is just not the original body, and won't correctly update if changes are made to the sketch that created this body. We consider this to be a warning (the yellow coloring as opposed to an error, which is red). Whether this caching is a good thing or a bad thing is debatable (and we do debate it internally a lot). One the one hand, it allows the design to successfully compute. But, that success is misleading, because the design is still not quite right. And, you may not find this out until you make some upstream change, and everything falls apart. So, it's a mixed blessing.
hope this helps,
Jeff
Jeff Strater
Engineering Director
