Deviation tolerance
Deviation tolerance
Remy18
Deviation tolerance
Remy18
Is there an option available te define a positive lower tolerance for a given dimension ? The lower tolerance is red highlighted when trying..
HughesTooling
Put a minus in the bottom field instead of a plus
Mark
Mark Hughes
Owner, Hughes Tooling
Remy18
Thanks a lot, i was looking for that.
Remy18
There're situations where customization of a dimension is more effective then changing the nominal dimension of the model. Is there a possibility to add a tolerance to a modified dimension ? Seems when a dimension is override, a tolerance type can be selected but isn't showed.
cmiller66
Hi RemyK,
With the caveat that I would not recommend manually overriding dimension text (much like exploding dimensions in AutoCAD) because then you're losing the true associativity of the design to the dimension value...  If you've manually overridden the text you can use the AutoCAD symbol code %%P to get the plus/minus symbol in the text.
FWIW, if you override the text and want to revert back to the default you can delete the current text and replace with <> .
Chris
Remy18
I agree, thanks for your help !
