第 1 条消息(共 5 条)
不适用
03-20-2018
01:59 PM
I’m using a stock off-the-shelf screw (SPAX #10 2” multipurpose self-drilling) as an OEM part for my product I’m designing. I want the screw head to sit flush with the surface of my part. I’ve read there are essentially two basic head angle standards: 82 and 90 degrees. I called SPAX to ask the head angle on the screw I intend to use. The customer service rep checked with engineering and told me the head starts at 30 degrees and then tapers to 45 degrees. That...doesn’t sound right? I assume I need to use a head angle in my design that meets the countersink bits common to machine shops.
How do I determine this to design my holes specific to the screw I intend to use? And how much additional relief do I need to build into the hole design to allow for powder coating?
已解决! 转到解答。
