Designs in assemblies and subassemblies are not up to date
We constantly have the issue that updates in designs (e.g. changes in length of parts) are not updated in the assembly.
A helpfull one is deleting the F folder in the cache. So far that solves it in Fusion on the pc/mac.
However we have 3 people working on design and inbetween I use my ipad pro to review and do markups on the designs that are in progress.
on fusion360 on ipad I keep getting incomplete, old designs with missing parts or wrong dimensions. Basically what we have/had on the pc.
No way to delete a F folder in the cache on my ipad pro. 😉
Some help would be great. Tnx.
innovatenate
Autodesk Support
Autodesk Support
This sounds like this may be related to this forum discussion.
http://forums.autodesk.com/t5/design-validate-document/issues-with-asemblies-in-latest-update-s/m-p/...
Which version of the mobile app are you using (A360 or Fusion 360)? You should be able to locate the version number in the settings of iOS9 or the app itself. I note that there are commands to located in the settings of the A360 app:
  • Clear Recent Data
  • Clear Offline Data
  • Clear Uploads Data
Have you tried using these commands?
I hope that helps!
Nathan Chandler
Principal Specialist
Thanks. That did the job.
