Hi Guys,
Looking for a bit of advice. New to f360.
This is a base I'm designing for a machine. The part will be cast steel in the End.
What I'm struggling with is the ribs to support the round post to all four corners. I'v tried various ways to make them but they're proving to challenge me a bit.
The method I've had most success with is to sketch the shape of the rib on the the base and push/pull it to the height I want. The vertical surfaces meet perfectly on the radius and will allow me to make nice fillets. The problem is then cutting the corner off. I've tried creating a plane on a angle through the part but when I cut it, the cut carries on to infinity and takes off the round post with it. Also I cant seem to get it to lock onto right angles. I've tried sketching guide lines for the planes but they always end up crooked.
The other way I tried doing it is to create a vertical plane, sketch the side profile of the rib and push/pull it to get the desired thickness. Which worked fine but the ends where it meets the round post and the short end aren't desirable. I can't get the fillets right to the round post as the surfaces don't meet properly. And I can't seem to find a way to trim the small tip of the rib be the corner recess to meet the radius around the bolt hole.
I'm not sure if either of these methods are a good way to go about this but ideally what I'm imagining is a way of combining both of them. Or just simply a different/better way of doing it if there is one?
Attached are some screen shots , showing the two different methods I've been attempting on each of the ribs. hopefully my explanation makes sense.
I plan to smooth everything off with fillets at a later stage. Any help would be much appreciated.
