- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey folks,
Quick question : how do you design correctly an adjustement clearance between parts ?
Let’s say you want to have two parts linked together with finger joints, and you want 0.1mm between the joints. You can create one part and offset 0.1 mm in the sketch, then extrude the two parts.
I also saw that you can create both parts with no clearance, then use the "offset face" tool to create the clearance.
Is there any other ways to do (efficiently) this ?
Thanks !
