design tips pls
design tips pls
Message 1 of 12
design tips pls
Hi ,
i need to design this object , do you have any tips for me ?
thanks
shadi
Replies (11)
Message 2 of 12
TrippyLighting
I am sure we will have some tips, once you have posted what you've got so far.
Message 3 of 12
TrippyLighting
If you don;t know what's the best way to start, imagine this object been made from a few simple shapes.
Message 4 of 12
thank you for replying. this is how far a got ( attached file)
Message 5 of 12
Beyondforce
Hi @Anonymous,
I thought I should pitch in as well 🙂
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 6 of 12
thanks you so much Ben! but why i cant open the file with F360 ?
Message 7 of 12
Beyondforce
You need to upload it first.
Ben Korez
| YouTube
Message 8 of 12
PhilProcarioJr
@Anonymous
Just click file -> new from design and select his file and it will open. You don't need to upload it first.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 9 of 12
now it worked ! your great man thank you so much !!!
Message 10 of 12
thanks i managed to open it without uploading
Message 11 of 12
TrippyLighting
Sorry I could not be more specific this morning. I had just time to load up the model befor I had to leave for work and don't have accesss to my Fusion 360 machine here.
When starting to design such objects try to break the geometry down into simple geometric shapes shapes. It is easier to do if you imagine that all the soft radii called fillets are removed from the object and you are only left with sharp edges. Usually in a CAD model fillets are applied at the very end of the design process.
The next thing you should think about are symmetries so if you have a circular pattern as in this case then you only have to design the geometry once and then pattern it.
The ability to break down complex objects into is key to designing in solid models.
Message 12 of 12
this is very helpful, thank you 🙂
