Design or Emboss Texture within a Drawing
hughntx
hughntx
Hello, I am currently working on a project where I want to add texture to a grip within the bounds of a sketch. Would this be possible to do? Or is there a way to CAM a toolpath using a trace toolpath wtihin the sketch to create a texture similar to knurling. The issue I am having is figuring out how to do a wrapped texture around a form body. I have attached the grip file I am working with. I was trying to emboss the texture pattern but I could not figure out how to emboss on a form and not a symmetrical shape.
g-andresen
1. geometric pattern > only with paid licence and extension
2. use emboss tool
(view in My Videos)
3. Try it with Fuzzy Skin tool in the slicer or with Idea Maker
günther
hughntx
Would there be a way to extrude or emboss 3D pyramids or diamonds onto the surface instead of cylinders? I couldn't figure out how to do that. What I mean is a full 8 sided diamond shape debossed into the surface to make a knurling texture.
g-andresen
@hughntx  schrieb:
Would there be a way to extrude or emboss pyramids or diamonds onto the surface instead of cylinders? I couldn't figure out how to do that.
1. embossing is done with 2 D profile
Instead of the circle, you can use other shapes such as diamonds, stars and irregular 2D shapes.
2. 3 D pyramid can be made with geometric pattern.
günther
