Design large objects while keeping mm scale
grunewaldrogier
Message 1 of 10
grunewaldrogier
Dear Experts, I have been doing my very best to find an answer, but I need help. I am an absolute novice and I wanted to design a metal plate 6.000 x 1.800 mm. To my surprise I found out, that the maximum canvas size for Fusion is 5.000 mm. Is this correct? And the main question: how can I keep the mm-scale? I do not want to scale down to cm or meters, as the dimensions then change. No one designs in cm, it is always in mm, even these large kind of objects. Thank you SO much for your help. BR, Roger from the Netherlands.
Replies (9)
Message 2 of 10
francesco.caprini
Hi @grunewaldrogier
5,000 mm is not the maximum size of the work area, and it is possible to design a sheet 6,000 × 1,800 mm.
Here’s a short video where I demonstrate this and also show you how to set the unit.
Francesco Caprini
Application Engineer
Message 3 of 10
Drewpan
The simplest way to solve this problem would be to use the built in fusion
units. As an example we know are that Americans are "different" and use their
very own measurement system called American Customary Units. This causes
all sorts of problems in Engineering. Ask NASA about Space Probes in Pounds
and Kilograms and new craters in the surface of Mars.
The fusion units system is driven by cm under the hood we don't see but there is
a selection of units available that includes decimal feet (5.125') or feet and inches
(5' 3") and of course it also includes Metric mm (1600.2 mm) and a few others. It
is actually possible to mix and match these units while modelling. Of course there
can be issues when us people who usually use Metric are forced to use this arcane
ACU system but the easy fix is, as I said, to use the fusion units system and simply
convert it at the end.
Fusion will remember whatever you input as a measurement in whatever units you
wish to use. In your case, if it is easier to input your measurements in Metres (1.6002 m)
then that is the way you should model it. When you are done then the last thing you
should do is change the units back to mm and all of the actual measurements will be
changed to the new units.
Cheers
Andrew
Message 4 of 10
etfrench
If you have the grid turned on, turn it off. It doesn't actually limit the size of a design.
ETFrench
Message 5 of 10
pkomatlapalli
Hi @grunewaldrogier,
Welcome to the Community!
Can you please let us know if the suggestions from francesco.caprini, Drewpan and etfrench helped resolve your question?
If they did, kindly consider marking it as an Accepted Solution so it can help others in the community. If not, please feel free to share an update, and the community will be happy to assist further.
Let us know how we did on Trustpilot.
Pavan Kumar
Message 6 of 10
grunewaldrogier
Hi Francesco, thank you so much for your reply. I was ill the last week, so everything was paused for a few days. Thanks and you are right, if you create a rectangle, then there is no problem. What I did was create a 3.000x900 mm square, and mirrored it to the side and down, so I ended up with a 6.000x1.800 mm area. This is where I got the message "out of boundaries" or something like that. I will try again to see if the message comes back. Again, thanks for your help!
Message 7 of 10
grunewaldrogier
Dear Francesco, thank you for helping me! You are right about the 6.000x1.800 mm rectangle. But what I did was create a 3.000x900 mm rectangle and mirror it to the right and down, to create the 6.000x1.800 mm rectangle. Reason being, that I need to add some slots in the corners and I thought I make my life easy by creating it once, and then mirroring it twice. But that is the moment where I get the "out of boundaries" (or something like that) message. Let me try it again, because maybe I was wrong. Again, thanks so much for your support!
Message 8 of 10
grunewaldrogier
Dear Andew, thanks so much! Does it actually work like that? So I can model in (let's say) cm, and when I'm done change back to mm? That would be a solution as well! Let me try that. Thanks so much for the tip!
Message 9 of 10
Drewpan
Yep it does. VERY handy sometimes for your sort of issue.
Cheers
Andrew
Message 10 of 10
TheCADWhisperer
@grunewaldrogier
I strongly recommend that you attach screenshots of issues that you observe and, Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply?
See my screenshot and file attached below...
Click on image above to enlarge the view.
