Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
design history not highlighting features after a body is converted to component
2 REPLIES 2
WyzeOwl
253 Views, 2 Replies
Recently, I have noticed that Fusion does not highlight features (3 dots above the design feature) in the design history timeline after a body has been converted to a component. Features that "pre-date" a component creation command are hidden from the "find" ability of fusion.  This behaviour goes both ways in that if hovering over a feature in history, that feature does not highlight in the model.  If I move the slider to before the create component command, the features in the model will then be visible to the highlight ability of Fusion.
In years of using Fusion, I have never seen this issue and in thinking back I am sure I must have followed the same work flow (bodies to components after investment in design time) without running into this Other than following a methodology of always create a component before investing too much time in a body only design, is there a way to turn this feature highlighting back on after a body is converted to a component?
2 REPLIES 2
jeff_strater
in reply to: WyzeOwl
I am fairly certain that Fusion has always worked this way.  It is just a limitation in the feature identification code that, once a body has been converted to a component, the features lose the ability to track their geometry.
Jeff Strater
Engineering Director
WyzeOwl
in reply to: jeff_strater
Yes, I remember watching a video years ago by (can't remember his name) who was demonstrating how to do Fusion. In that video he mentioned that best practice was to always create a component first, then start modeling. I am sure in that demo the presenter must have stated various good reasons for that work flow which must have included avoiding this issue. Thanks for the reply Jeff.
Technology Administrators
