Design help
Design help
snoofydog
Design help
snoofydog
I have been struggling with creating something similar to the attached image and need some help..
i need an organic like dome with a flat bottom, which is then shelled so its lightweight.
i also want organic shaped pockets cut into the surface, where another material will be inserted
Im sure someone will whip it up in 5 minutes and leave me dumbfounded 😁
TrippyLighting
It's really relatively simple, if you know what tools to use.
For the screencast I simply made a T-Spline (sculpt)  cylinder with 24 vertical division.
I selected every second vertical edge and scaled these in to arrive at a star shape.
Then I selected the upper star-shaped edge and enable the soft modification option and pled around with the controls.
I scold inward and pivoted the star-sheped eggs around the vertical axis.
then I use the "Modify->Fill Hole" function to lose the hole.
Then I thickened the shape.
The Hole fill function leaves artifacts and I'd usually not use it but fill it by hand with quads only, but for a quick shape it works well enough.
snoofydog
That's great. Thanks
What about inserting multiples of something like the attached, that are cut into the surface and would be a different material?
TrippyLighting
Two questions before I proceed:
1. Ho is it going to manufactured ? I assume 3D printing.
2. Do you want these shapes cut into the surface or protruding from the surface ?
snoofydog
Hi TrippyLighting
No 5 axis machined.
Both, I want the shapes to be a different materials. So I would like pockets cut out of the body and inserted with another material that will be protruding from the body.
If that makes sense?
TrippyLighting
Yes, it does. I'll see if I can get to it tonight.
My thinking at the moment is t simply to design these squiggle blobs also as separate T-Splines and then use "Modify -> combine" with the cut option and Keep tools enabled.
That way you'll get pockets cut out of the main shell, but retain the squiggle blobs (sorry, could not come up with a better name 😉
