Design help
Design help
omarhusseinramadan
Message 1 of 9
Design help
omarhusseinramadan
Hello, I’m currently doing the ‘Introduction to Mechanical Engineering Design and Manufacturing with Fusion
360’ course however I’m struggling with the first design challenge (attached below).
If someone could please send a step-by-step explanation of how to do it, I would be very grateful.
Thank you very much.
Replies (8)
Message 2 of 9
CGBenner
@omarhusseinramadan
Welcome to the Community.  Can you share some more information about the class you are taking, or a link to the site?
Have you started the exercise?  Maybe you could share what you have done so far for others to take a look at.
Did your question get successfully answered? Then just click on the 'Accept solution' button.
Let us know how we did on Trustpilot.
Thanks and Enjoy!
Chris Benner
Message 3 of 9
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
Time spent on the tutorials and self paced learning will not be wasted. Also check out the three RULES that are pinned to the forum for further guidance.
Cheers
Andrew
Message 4 of 9
omarhusseinramadan
Hello, The course Im doing is about autodesk fusion design and focus more on mechanical engineering, a part of it includes creating renders, joints, animation, as well as creating and simulating toolpaths and simulations in general. The course link: ' https://www.coursera.org/learn/mechanical-engineering-design-manufacturing/home/welcome '
I've started the exercise this is what i have so far:
I cannot figure out how to remove the areas marked.
Message 5 of 9
etfrench
What are the instructions in the tutorial?
ETFrench
Message 6 of 9
omarhusseinramadan
 These are the instructions. The link is in the original post
Message 7 of 9
CGBenner
@omarhusseinramadan
It looks like where you are struggling is with Shell.  @etfrench is there a way in Fusion to select faces that you not want to include in the Shell command?  Am I seeing the problem right?
Thanks and Enjoy!
Chris Benner
Message 8 of 9
etfrench
I can't access the site to see the individual instructions.
You can select multiple faces in Shell which should entirely remove those faces.
ETFrench
Message 9 of 9
CGBenner
@omarhusseinramadan Hello, do you still need help with this question?
Thanks and Enjoy!
Chris Benner
