Design based on joint limitations.
acondax
acondax
Hey everyone.
I am working on designing a cabinet that requires the use of some hinges. I've found a perfect hinge on McMaster-Carr for the job and (I believe) I have successfully applied all the necessary joints and contact sets in order to see it behave in a realistic manner.  Now I'm stuck.
I want to drive this hinge to two possible positions, open and closed (see attached images). I will be modeling cabinetry around this hinge and want to ensure there are no unwanted collisions during the opening and closing of the doors. I don't know how to move these joints in a controlled manner. I can click and drag on the model and it might or might not move a single pivoting joint properly; it seems like it behaves randomly. Does anyone have a recommendation for proceeding?
I've attached my project down below in a post reply so you can open it up and see the behavior for yourself.
Thanks!
Athan
Closed position should have left-most wall perpendicular to base.Closed position should have left-most wall perpendicular to base.Open position should have parallel base and headOpen position should have parallel base and head
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Currently, attachments are only possible via global replys.
acondax
Here it is, I was wondering why I wasn't able to attach it to my original post.
g-andresen
This is caused by a problem with the forum software.
günther
jhackney1972
I do not think you really want to add a controllable motion, the door it is mounted to will do that.  You mainly need a couple of Joint Limits applied which I did on Rev 1 and Rev 3 to make it stop at your desire end angles.  I also add a Motion Study to it where you can drive it if desired.  Model is attached.
Edit: I do not think you need the Contact Set
John Hackney, Retired
