Design a sphere and attach to a body.
Message 1 of 20
Trying to add a 1.25" sphere to the end of this project.
When trying, the entire screen turns red.
Need help to figure the sphere command out.
See attached drawing.
dlw
Replies (19)
Message 2 of 20
whittakerdw
Where exactly are you trying to attach a sphere? At the end isn't really giving enough information.
Message 3 of 20
At either end toward the top of the curve and centered so it is connected to the body enough to support it.
Will use as a massage tool.
Message 4 of 20
g-andresen
maybe this is the problem:
günther
Message 5 of 20
whittakerdw
Is it turning red like @g-andresen has shown? If so then just change to join or new body/component as opposed to cut.
Message 6 of 20
whittakerdw
Is this similar to the issues you are having?
Message 7 of 20
g-andresen
Basically I refuse to help with the modelling of weapons, whatever they may be.
Unfortunately I did not open the file and the term was unknown to me.
So I fell into this "trap".
günther
Message 8 of 20
HughesTooling
The sphere primitive is quite useless for accurately placing and is not parametric so design edits will break its position. If you want to accurately place a sphere create a plane in the correct place then draw a D shape and create a revolve. You will be able to create the plane and sketch parametrically so edits will not break anything.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 9 of 20
laughingcreek
Yeah, what @HughesTooling  said.
I have a few suggestions, in addition to sketching the sphere shape and revolvning, and not using the sphere primitive-
-Don't use the move tool.  There are few circumstances where you should use it, and this isn't one.   Getting in the habit of using it will cause you problems as your designs get more complex.
-take advantage of symmetry. both left and right, but also up top and bottom.
here is a screen cast incorporating the things @HughesTooling said and my additional suggestions.
Message 10 of 20
laughingcreek
hmm...I've try the screen cast again
Message 11 of 20
chrisplyler
Basically, I refuse to help with the modelling of fat chicks. So we have something in common.
Message 12 of 20
etfrench
In this case the OP is turning a weapon into a non-weapon, unless fighting massages is the latest type war Smiley Happy
ETFrench
Message 13 of 20
g-andresen
Hi @chrisplyler  &  @etfrench ,
don't hide behind such weird slogans but talk factually about content.
günther
Message 14 of 20
Thanks for responding with you opinion.
I seriously agree .
It was my mistake for naming the drawing as a Massage Tool.
dlw
Message 15 of 20
The sphere was created next to the Massage Tool then moved into position and combines.
Looks great.
It's in Cura 4 now. Will print later.
See attached design.
Thanks for the tip.
dlw
Message 16 of 20
chrisplyler
If stating what I would not help model is hiding behind a weird slogan, and you don't like that, then why did you state what you would not help model? Don't tell me not to do exactly what you just did.
Message 17 of 20
g-andresen
Just stick to the facts.
Where did I make such a statement?
 # 16 ... Don't tell me not to do exactly what you just did.
günther
Message 18 of 20
etfrench
The OP indicated he was adapting a weapon (brass knuckles) to be a massage tool, which is not a weapon.  Changing a weapon to a peaceful use should be considered a good thing.
ETFrench
Message 19 of 20
chrisplyler
Post #7.
Message 20 of 20
g-andresen
Now it's going crazy.
Do I appeale to follow me?
günther
