- Mute
- Permalink
- Report
I understand how to make a dimension in a sketch a function of another dimension in that sketch.
Is it possible to make a dimension a function of a dimension in a different sketch (In the same component or a different one).
As a concrete example, if you have a pulley defined in one component, can you dimension a shaft in a different component that has a diameter that is a function (bore size of the pulley minus a clearance value). I know that I could project the profile into the drawing and make the diameter a function of that projection, but my understanding is that the projection is static (not linked to the size of the original).
Or is there a more elegant solution to this problem that I am not aware of?
