Message 1 of 8
02:24 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working with a scan file of the interior of a cargo van, and am trying to reverse engineer the hole positions to a datum (to then design fixtures that mount to the holes). The scan is essentially a surface, and is therefore infinitely thin. Because of this, I cannot create a "mesh section sketch" at a single plane that intersects all of the holes. Each hole is on a slightly different plane due to the resolution of the scanner.
What would be the best way to derive the hole locations from a scan file like the one I have attached?
Thanks for the help!
